Ghost1990
This guy seemed to have done itHeck it’s gonna sound biased but I even have my old 5.7 short block that needs machine work that would be a good starting block for a stroker build. It’s for sale cheap haha
So, question... Are the 6.1 and 5.7 the same block with different BorexStroke? If so, then I don't see the reason for this swap over a big bore/stroker build unless you get one for an absolute steal and it's close to a direct drop in...
And a 6.1 block can be over bored, too?While you can do a stroker with a 5.7 block, you can't do a big bore with one. A stroker with a 6.1 block allows you to use Apache heads if you so desire.
Any block can be overbored to a point, however I think you missed the point. Can't use Apache heads on a 5.7 block unless you overbore it more than most people would be comfortable with or notch the bores for valve clearance. You don't have to do that with a 6.1 block. Also the 6.1 was designed to be a performance block, including piston oil squirters that the 5.7 does not have.And a 6.1 block can be over bored, too?
Sent from my magic 5-inch
truck is 13 years old and still sexy as hell.This guy seemed to have done it
What's so great about apache heads? Or is that just a certain casting?Any block can be overjoyed to a point, however I think you missed the point. Can't use Apache heads on a 5.7 block unless you overbore it more than most people would be comfortable with or notch the bores for valve clearance. You don't have to do that with a 6.1 block. Also the 6.1 was designed to be a performance block, including piston oil squirters that the 5.7 does not have.
They have been called the best cylinder head Chrysler has ever produced. Huge valves and ports, was the basis for the hellcat head (same design, different composition aluminum). A 6.1 based 426 stroker with P&P'd Apache heads, about 10.5 compression and a fairly mild (for a race engine running on class required street premium gas) roller cam, a high rise intake and a single 4bbl carb made north of 720hp naturally aspirated.What's so great about apache heads? Or is that just a certain casting?
Well **** forced induction, that'd be all I need! How much do you think one would make ballpark with a street-daily/pro touring type cam made to handle an SCRB truck's 4500-5000 pound weight?They have been called the best cylinder head Chrysler has ever produced. Huge valves and ports, was the basis for the hellcat head (same design, different composition aluminum). A 6.1 based 426 stroker with P&P'd Apache heads, about 10.5 compression and a fairly mild (for a race engine running on class required street premium gas) roller cam, a high rise intake and a single 4bbl carb made north of 720hp naturally aspirated.
Couldn't tell you for sure lol, but my buddy has an older Arrington 440 stroker with Apache heads that makes somewhere well north of 600. I'd take a look at the various builders (Indy, HHP, Muscle Motors, Inertia, etc) and see what their offerings are rated at. Should give you an idea.Well **** forced induction, that'd be all I need! How much do you think one would make ballpark with a street-daily/pro touring type cam made to handle an SCRB truck's 4500-5000 pound weight?
That thing was a ****This guy seemed to have done it
New here, I know this is an old thread, but hope I can start it back up.
I recently purchased a 2006 Jeep Commander Limited Ed. that had been seized by LE. , and discovered it has a 6.1 engine swapped into it. I am not sure what all was done, but it certainly looks to be a professional job.
It runs great, but does have some of the Jeep TIPM issues which I read is common. I almost had it flashed with another TIPM but, now I thinking that may not be a good idea due to it may revert the tune to the old 5.7 according to the VIN.
So, can anyone tell me about these swaps, Is it likely that the ECM etc. from the 6.1 was used in the swap?
and is there any other info I need to know?
I would like to know how to determine the year of the 6.1 also.
Thanks?
Most 6.1 block can be bored out to 4.09, 4.08 to be safe. 03-08 5.7 blocks ca be safely bored out to 4.0 , but there are no off the self pistons for them (http://www.shophemi.com/p-1168-arrington-410-short-block.aspx )
Miniman 5.7 Bore to use Apache stock size valve heads is 3.957(.040 over) , the Intake valve will physical hit the edge of the stock(5.7) bore.
Apache heads are what come stock on the 6.4s,392s, Hellcat & Demon , Hellcat/Demon head is a different casting, it has more material in the Intake mounting area.
There have been modified(port and Polish) Apache heads that are flowing in the high 300 CFM(380-390ish)
How did you do it to wire up the coils and get rid of the ignition wires ?I just finished the 6.1 swap in my 03 Ram. If anyone needs advice on the swap let me know.
You can either solder new connectors on or use adapters:How did you do it to wire up the coils and get rid of the ignition wires ?
did u change timing covers to make the intake clear ?
