Yes, however...are you willing to do/can afford getting rid of your clutch fan and switching to an electric fan (permanently), creating a custom air intake to the filter, rerouting and lengthening the alternator and throttle body wiring (at minimum) to their new locations, creating new A/C hoses to route to the compressor's new location and either a custom radiator or some creative hose work?
You do realize you don't NEED the 6.1 timing cover and accessories to use the 6.1 heads and intake, right....?
Before you go off half cocked, you don't need all that to go fast. Check out his truck: https://www.ramforum.com/members/chefred112.402/
-fastfreddie-
one quick 05 5.7 hemi qc... with over 309k on block... best et: 12.1 @113
-Inertia Motorsports 392 stroker assy born 7/2014
Prior to the stroker he was running big valve heads and a cam and running mid to high 12's all motor.
I mean, unless you really wanna do all that work and spend the money; knock yourself out lol
-fastfreddie-
I can clarify (dunno what clearify is). Nobody does research anymore....if you're insistent on using the 6.1 intake, get the modified timing cover that moves the alternator & compressor out of the way. You still have to lengthen the throttle body harness and convert to an electric fan, plus fab your own air intake tubing. This has been done for well over a decade, have you looked up anything...?Can you clearify then how I can use the 6.1 heads etc and use my 5.7 accessories because where the throttle body on the 6.1 interferes with the 5.7 timing cover
Yeah I have I’ve read every single post on the forum Referencing t referencing he 6.1 I was just a bit confused because a shop told me otherwise.I can clarify (dunno what clearify is). Nobody does research anymore....if you're insistent on using the 6.1 intake, get the modified timing cover that moves the alternator & compressor out of the way. You still have to lengthen the throttle body harness and convert to an electric fan, plus fab your own air intake tubing. This has been done for well over a decade, have you looked up anything...?
Can't get EVERYTHING from a single forum lol. If I did that from the beginning I would've never done some of the mods I've done lol. Shops are hit or miss unless it's a reputable one with modern Mopar experience. Yes, the 6.1 intake does flow better as do the heads than the early 5.7 heads, though you have to decide if the cost of certain alterations to use them are worth it. I've shown you what modded 5.7 heads with the stock intake manifold can do. You said you didn't want to spend an inordinate amount of money but then you seem hell bent on doing a full 6.1 top end swap (which WILL cost you extra to make it work properly). This on top of a possible rebuild and/or long block replacement.
Yes the shop is strictly mopar preformancd,but everyone doesn’t know everything, how much power will be lost by using a stock 5.7 top end?Can't get EVERYTHING from a single forum lol. If I did that from the beginning I would've never done some of the mods I've done lol. Shops are hit or miss unless it's a reputable one with modern Mopar experience. Yes, the 6.1 intake does flow better as do the heads than the early 5.7 heads, though you have to decide if the cost of certain alterations to use them are worth it. I've shown you what modded 5.7 heads with the stock intake manifold can do. You said you didn't want to spend an inordinate amount of money but then you seem hell bent on doing a full 6.1 top end swap (which WILL cost you extra to make it work properly). This on top of a possible rebuild and/or long block replacement.
Unrelated but I can’t seem to remember if I thanked you for your service so thank you for protecting our freedoms
Yeah he told me he had to but this is also a mopar racing shop and doesn’t like to do things half wayNever have to, that's what we're here for
I have doubts about that shop if they told you that you HAD to. Depends on how it's put together and tuned. You need to really sit down and think, then balance your performance goals and budget. No point going any further until you have a direction.
Awesome thanks alotMax you might post some of questions on HTC, there are a couple trucks there with 6.1 heads/manifolds...
Any clue what he did with the ac/alternator?
