6.4 HP/TQ curve
U&A
2016 3500 SRW
6.4 HEMI
I’m having a hard time finding The line graph that shows the horsepower and torque curve of our 6.4’s specifically for our trucks.
Has anyone found one before?
Administrator
Found a Dyno run done by AFE for their 4" stainless cat-back exhaust.
They have the testing specs at the bottom, the baseline numbers are in blue49-42056-bi1600.1530816982.jpeg
U&A
U&A
2016 3500 SRW
6.4 HEMI
They have the testing specs at the bottom, the baseline numbers are in blueView attachment 143188
Thank you sir,
Greatly appreciate it.
The HP curve is a lot more linear then I thought it would be.
The torque curve looks great for a gasser.
McBroom
Denison Tx
Hemi 6.4L
What does Ram say the hp n tq rating is? Hp I’ve heard near the 400 mark is that right?
I couldn’t see that chat very well. I’m on my phone(all I got)
Blue Streak Pearl off-road
mtnrider
Georgia
Not sure what Ram quotes but that truck pulled 312 max HP. and 325 max torque (stock).
McBroom
Denison Tx
Hemi 6.4L
Wow I would’ve thought those numbers would be a lot higher
U&A
U&A
2016 3500 SRW
6.4 HEMI
Rams numbers are not power to the ground numbers.
No manufacturer does actual power to the ground numbers
McBroom
Denison Tx
Hemi 6.4L
I understand that. I guess I meant to say factory engine advertised numbers.
I really like the WTG numbers and I know there’s room for improvement on that.
But a major drawback is that there are very few companies that make go fast goodies for our big added 6.4 Trucks
SouthTexan
408 CTD
jaflowers
6.4 hemi
Lots of variables when you do a dyno run that will affect the results. Setting up the machine properly, wheel weight, tire weight, wheel diameter...lots of differences.
mohemipar
2017 Laramie
6.4 Hemi, 4.10's
You can pay SAE $50 for the official certification. ---
J1349 Certified Power Engine Data for Chrysler as used in 2014 MY Ram 2500 & 3500 Pickup <10,000 GVWR - Level 1
Wheel end dynos are not always the best to getting actual numbers depending on what kind of dyno is used and if it is properly set up for the vehicle. They are good are noticing changes between mods though.
This. Best reason to use a dyno is to get an idea of increases from mods and see power curves. A lot seem to use them as a junk measuring contest which is at least entertaining. There are so many factors that can effect numbers on a given day. A HP or torque number by itself doesn’t mean much.
Does that print out say it was running 37’s? From what I’ve seen more dynos than not show all of the SRT Hemi’s make more than advertised. Given that the 6.4 HD is a mash up of all these parts I wouldn’t be surprised if it’s also a little under rated. But their goal with these trucks was longevity. The factory tuning, transmission gearing and exhaust are your biggest performance hang ups off the dealer lot. The engine itself is a great piece.
loveracing1988
Clarkston, MI
That's still a 22% drive train loss which is pretty good for a automatic truck.
