Found it:
Ram Truck Instrument Cluster Self-Test Procedure (DS)
NOTE: 2013 & up with Premium Cluster - Hold the Down button on the steering wheel controls, then move the ignition switch to the accessory position, not run.
Purpose
The instrument cluster self-test will place the instrument cluster into its self-diagnostic mode. In this mode the instrument cluster can perform a diagnostic test that will confirm that the instrument cluster circuitry, the gauges, and the indicators are operating as designed. During the self-test the instrument cluster circuitry will position each of the gauge needles at various calibration points, illuminate all of the segments or portions in the Liquid Crystal Display (LCD) unit, and turn all of the indicators ON and OFF.
Successful completion of the self-test will confirm that the instrument cluster is functioning correctly. If an indicator issue still exists, the source of the problem is likely with the
CAN data bus, the Powertrain Control Module (
PCM), the Totally Integrated Power Module (
TIPM), the Transmission Control Module (
TCM), the Occupant Restraint Controller (
ORC), the Controller Anti-lock Brake (
CAB), the Wireless Ignition Node (
WIN) or the hardwired inputs to any one of these electronic control modules. A diagnostic scan tool will be necessary to diagnose these components. Refer to the appropriate diagnostic information.
Procedure
- Ensure that the ignition switch in the OFF position.
- Depress and hold the Odometer/trip Odometer button.
- Move the ignition switch to the ON position. Do not start the engine.
- Release the odometer/trip odometer button.
- The instrument cluster will begin to illuminate all of the operational segments in the LCD unit and perform a bulb check of each operational Light Emitting Diode (LED) indicator. The LCD segments and LED indicators remain illuminated as each gauge needle is swept to several calibration points and back. If a VFD segment or an LED indicator fails to illuminate, or if a gauge needle fails to sweep through the calibration points and back during this test, the instrument cluster must be replaced.
- When the self-test is completed, the instrument cluster will automatically exit the self-diagnostic mode and return to normal operation.
NOTE: The self-test will be aborted if the ignition switch is turned to the OFF position, or if a vehicle speed message indicating that the vehicle is moving is received from the PCM over the CAN data bus.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 113101 miles.
