6.4L engine pros have a question.
retired
montana
4EA4C75D-85E2-4B6E-A5B4-4299653A6F3B_1_201_a.jpeg What are the purpose of these two plugs? On my 2020 6.4L the lower one was dripping oil when I got it. It would drip down and then drip off the bottom of the oil filter cooler. I snugged it up (it was loose and turned a turn or so before snugging up and this was at literally 500 miles or less when I noticed it) and it stop dripping but I have always wondered what these hex plugs are for are they just passages that were drilled for engine assembly that serve no purpose or do they serve an actually purpose.
retired
retired
montana
ok I found the answer should have figured it out by looking at it.
retired
retired
montana
I thought some of the engine pros would know. I will wait until tomorrow to reveal what they are in case someone chimes in with the answer.
crazykid1994
Look like plugs for an oil cooler or to relocate the oil filter
retired
retired
montana
Apparently they have a ball bearing and spring to control oil pressure. Mine was leaking from the bottom one (brand new probably less than 500 miles when I noticed it) which is what got me curious when I read about another new one doing the same thing.
thkbaron
Minnesota
So is that what they are for is an oil cooler?
retired
retired
montana
So you just crank the thing tight then?
I just snugged it down and it stopped leaking. I did not crank it tight per se. apparently it is just a pipe plug. mine has not leaked in the last 6500 miles.
