We have guys running 5w30 redline in the 6.4, and so far u&a loves it. Mind you 0w40 redline is way thicker then 0w40 fca specs.
0w40 redline operating visc 15.3
0w40 srt hemi oil 13.7 but shears a lot, at the end of interval cSt in 10's or 11's. look at uoa's blackstone thread.
5w30 redline operating visc 11.9 but most uoa's have it over 12. redline 5w30 is way thicker then 0w40 srt oil at end of interval, no shear.
My point is this, 30 weight even 5w30 will flow better in the cold then 0w40, but 5w30 redline will even be thicker at operating temp then srt oil throughout much of an interval thanks to the shear from 0w40 PUP/srt. Basically, 5w30 redline performs better in the cold and warm then 0w40 spec oil.
Broken down even farther.. 0w40 is supposed to tell you something about the winter rating and the weight, but in reality they both are wrong with this particular weight with fca spec. The winter rating is misleading because of the weight, it is no where near 0w30 or 0w20 in cold performance, 40 weight is too thick. And to make it worse, the 40 weight is not a true 40 weight, because of the swing winter rating to weight, the oil is full of temporary additives to make it seam like 40 weight, when in reality 0w40 srt oil is a 5w30 most of the time in the sump, FACT.
The advantage of using 5w30 outright is less swing winter rating to weight, meaning less vii's, meaning less contaminants during the interval. But not every 5w30 is appropriate, it should be a "thick" 5w30, in the high 11's cst. I say this because you are already using redline, most of the time I don't get people to switch brands, but maybe you should switch weights, imo 5w30 redline is the best choice for the 5.7 or the 6.4, and the only time I would go off of that is if you still had cold piston slap you could even use 0w30 redline in 6.4, for same reasons the cSt will be thicker them 0w40 throughout the interval, but the 0w30 redline would be as good as possible cold performance.
Flat out 5w30 redline is hemi honey, 0w30 is a close second. It has everything a hemi needs, good hths, great additive package and base oils, and most importantly very good cold performance. 0w30 redline you loose a tad warm performance but will even be better cold performance. I think the only 40 weight redline that should be used in the 6.4 should be 5w40, and this is because of the guys who tested this prior, guys like kyle and tj. But you wont like that if you have cold tick, which it sounds like you do, that is why i say look hard at 5w30 or even 0w30 if you have poor cold performance.
Look close at these charts.. mind you 0c is 32f, so look how thick all oils are even just at 32f!
5w30 will be over 250 visc at 32f, and 40 weight will be better then 3 times that. That is why you get cold tick, the oil is so thick there is no oil on the lifters. Also, you can try putting hammer down to the floor before you turn key, pre oil lifters, then take foot off gas, (your truck wont start just turn over and rotate without starting), then start truck how you normally do, in theory this should oil lifters at start up. worth a try anyhow..
