I was pleasantly surprised at how little DEF I use when not towing.
I found this article very helpful.
Q. How can an operator determine how much DEF they will need/use? A. DEF consumption will be approximately 2% of the diesel fuel consumed. Another way to consider it is that DEF will be consumed on a 50 to 1 ratio with diesel. (For every 50 gallons of diesel fuel burned, you will use 1 gallon of DEF).
If you know the average fuel consumption of a vehicle, you can easily calculate the amount of DEF that will be used. Annual miles for average truck = 50,000 miles MPG for average truck = 8 mpg 50,000 miles / 8 mpg = 6,250 gallons diesel fuel per year DEF usage @ 2% of fuel consumption = 125 gallons of DEF / year 125 gallons / 10 gallon tank (average size) = 13 DEF fill-ups / year Example…Heavy duty Annual Miles per Vehicle Annual Total Miles Average MPG per Truck Average DEF Tank Size (on vehicle) Annual Fuel Usage (gallons)
Consumption per Gallon of fuel Estimated Annual DEF Consumption DEF FillUps per Year 120,000 120,000 6 20 20,000 2% 400 20 Annual miles for average truck = 120,000 miles MPG for average truck = 6 mpg 120,000 miles / 6 mpg = 20,000 gallons diesel fuel per year DEF usage @ 2% of fuel consumption = 400 gallons of DEF / year 400 gallons / 20 gallon tank (average size) = 20 DEF fill-ups / year
Example…Medium Duty Annual Miles per Vehicle Annual Total Miles Average MPG per Truck Average DEF Tank Size (on vehicle) Annual Fuel Usage (gallons) Consumption per Gallon of fuel Estimated Annual DEF Consumption DEF FillUps per Year 50,000 50,000 8 10 6,250 2% 125 13
