87bluebird
- Jan 28, 2017
- 9
- 0
- 2004
- 5.7 hemi
I have a 04 ram 1500 5.7 hemi 4wd. And want to put a six speed manual transmission in it. My plan is to find a g56 from a 06-08 ram 2500 with the transfer case flywheel and clutch. And on the interior get clutch and brake pedals, steering column and gauge cluster from a 03-05 v6 or 4.7 5 speed truck. Wire the clutch pedal into start and cruise circuits and wire in the reverse light. And have ecm programmed to delete transmission codes. Questions I have not been able to to figure out are:
what exactly to use for driveshafts will I need custom driveshafts?
Is the g56 longer or shorter than the automatic?
are speed sensors different?
Who can do the programming of the ecm?
Is there anything else I am missing?
Has this been done before?
I tried searching but couldn't find much of anything
