66RFE & 68RFE normal temps?
U&A
2016 3500 SRW
6.4 HEMI
So in another thread about transmissions I mentioned my temperature that my transmission gets up to, to other gentlemen that drive half tons (65RFE) and They thought it was very high.
On a hot summer day (70's +) it hovers around 17O-175 degrees when iv been on the highway for a good 15 min and stays there.
In town its about the same.
In 50-60 degree weather on the highway its around 130 150.
In 30 degree in town durring a 15 min drive (city) its around 110-120 at most
Any colder than that and it barely brakes 100 (15 min drive in town) and a lot of times its under that.
Thanks for your post in advanced
RoadDog66
Western MD
That's nothing, mine is typically high 160's low 170's all the time with normal driving. So far I've never had any of the countless computers, sensors or alarms tell me anything is wrong.
Clewis9593
Blaine MN
My truck generally will run at 160-165. Towing the trailer it will run maybe 165-170.
U&A
U&A
2016 3500 SRW
6.4 HEMI
Thanks guys. When i tow around 10,000 in 60-70 degree weather it breaks 180.....maybe not 60's but for sure it will in the 70's
RoadDog66
Western MD
Towing our 5'er in the hills it'll hit 180's maybe 190 briefly if I recall correctly.
RAM_Designs
Rockwall, TX
6.4L Hemi
168-172 is standard for me driving in weather from 40-90*. If I idle over some hot concrete it'll creep to 175-180*. I have never seen it below 160* once fully warmed up. This is the main reason for getting added capacity tranny and rear diff covers.
SouthTexan
408 CTD
Mine is 170°F +/-5 empty. Towing, it will get up to 180°F +/-5.
180°F is normal operating temp according to this ATSG article.
"Drive vehicle if necessary to
bring fluid temperature up to normal operating
temperature of 82°C (180°F).
INTRODUCTION
DODGE RAM 68RFE
MN-Ram
MN
6.4L Hemi
Mine is almost always at 170-172 after it warms up. When I tow it is usually between 170-180, but I haven't towed over 7,000lbs with it yet.
NewBlackDak
6.7L Cummins
Mine is always 170-172, empty. I've never seen it above 180.
stevenmicheal
