ScubaSteve178
The solenoid pack TSB/recall/whatever had to do with shift issues caused by a loose pinout in the connector of the solenoid pack. The issue usually causes a check engine light to pop up, and has some pretty obvious shift/drivability issues associated to the tune of limited speed and gear selection. Generally speaking, pretty clear whether or not its the solenoid TSB issue or if its a valve body problem.
