First off, this is not a thread asking if tow haul is bad for your tranny and when to use it. In fact, I have a theory that having T/H on all the time is better for the tranny in all uses. The 68 rfe behind the cummins is known to burn up the overdrive clutches due to a lack of line pressure and also because it shifts into those overdrive gears too early in the name of fuel mileage. Correct me if im wrong, but T/H increases line pressures, and I know it changes shift points to higher RPMs. So to me, it would seem that always have T/H on would in fact make your tranny last longer due to the increased line pressures and kicking into the overdrive gears later, thus preventing the overdrive clutches from being burned. In my "field tests" my fuel mileage has not actually dropped a significant amount, at least nothing that couldnt be explained by other variables. Your guy's thoughts?
