7 Pin Trailer Plug
freekie
On the 7 Pin Trailer plug can anybody tell me if the 12v / Hot connection has a fuse located in the fuse box or some place else? Mine has no power to it and I can only assume its a fuse. Its factory installed 7 pin trailer plug.
Jackfate
Funny you ask that cause I know it's at one o'clock ( just clockwise of the notch ) and I thought I may have popped it when I plugged in my tt to shore power with it still hooked up to truck . I was told don't do that . Well mines ok but I to would like to know where that fuse is . I'd have started pulling fuses if my line didn't show power but it does show power so I got nothing to look for[emoji848]
Hope someone chimes in with pictures[emoji3]
F
freekie
yup thats the pin Im talking about. I found one site that says its f30 fuse and another says J1. I havent had a chance to look yet but I dont think my truck has a F30 fuse.
Galion
Edmonton, AB
There's a fuse in the fusebox under the hood, I forget where exactly but It's a pink mini J case type: 197946d1394153884-new-fuse-back-ordered-img_0063.jpg
Check the diagram on the cover of the fusebox, it's labeled there. I know from when I bought my trailer and hooked it up the bad home wiring job the previous owner had done blew the fuse right away. :flipthebird:
F
freekie
J1 Fuse was it. 40 amp. Now what caused it to blow....
