8.4 Nav Screen protector
Kinetic
Anyone using one? Any feedback? I'm looking at getting the Mopar one made for Jeeps but fits any 8.4
Jwithing
STL
Get it. It not only keeps it clean, but makes it look higher end with a glassy look. Make sure you quadruple clean your screen. Mine has a couple of dust spots that created small bubbles. My kit came with two and I'm just to lazy/busy to reclean and put the new one on.
Kinetic
Kinetic
Just ordered the Mopar kit so we'll see how good it turns out.
rossbourne14
2016 Ram 1500 Sport
be sure to post results! really debating on doing the same.
aladin_sane
I have the same one from amazon linked above.
mtnrider
Georgia
They look glossy, Seems like they would create a lot of glare?
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
I also have the amazon one posted above. No glare, easy to clean.
Well worth it
Irongoats
Las Vegas
2015 Ram Sport
Got it looks and works great no issues. I think it even gives it a clearer picture if that's possible.
yillbs
OP has a 2018, his IS actually glass. I presume you mean 2017 and under will look like higher end with the protector?
2016Bighorny
Wisconsin
I just ordered the Mopar screen protector as well (82215337), I will post my review in here as soon as it arrives and I get it put on.
Jwithing
STL
Ah, yeah, didn't know they started putting glass in 2018... Well, it should at least look the same then lol
unxpctd
Minnesota
2021 PW 75A
I ordered the $12 Amazon one a couple months back. Put it on a couple weeks ago. Looks great. Had to work out a couple small bubbles but got it done. Glossy look and no issues with the touch screen. As was stated...be sure to clean your OEM screen well before putting it on.
Hemimania
Central NJ
unxpctd
Minnesota
2021 PW 75A
I use a screen cleaner with microfiber cloth that I keep in my glove box...but the kit from Amazon had a little wet pad that you can use to clean it. A damp cloth (not soaking wet) would do the same thing. After that use the little pad that comes with the kit.
Also included was a small suction cup to assist in mounting it. Worked great...just had to work a couple small bubbles out after getting it on the screen.
2016Bighorny
Wisconsin
I received mine yesterday. Put it on the screen last night. It is GREAT!!! Looks ten times better!!! The display is actually crisper and more defined, if that makes any sense. And you get two in the package!!
