8.4 Upgrade
BUGGS99
Minneapolis
So i found a 8.4 and a new bezel for a great price on Craigslist!! Question is, I know there is threads, but I am wondering is it at all plug and play? Guy seems to think so....
I have a 2015 Ram Black Edition, has the 5in. in it now, back up cam, and i Believe a 7 speed blower. If I buy the screen and bezel, what else do i need?
Thanks!
Witch
Hemi 5.7 liter
I think it should have rear camera, USB, remote start FM and nav antennas & the T harness connections
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Thanks!
You will need a 7 speed conversion harness, bypass plug and the correct HVAC module for a factory 7 speed truck.
Parts Required For MOD:
01. 8.4 Uconnect Radio (VP3/RA3 - Non-Nav) or (VP4/RA4 - Nav)
** For Compatible RA4 Radios see here. **Check car-part.com, Schram, ebay, etc.
02. SINGLE ZONE OEM 8.4" (MTC) BEZEL: 1UJ96DX9AF (AC, AD, AE, etc)
** Optional: DUAL ZONE 8.4" (ATC) BEZEL, while not preferred, will work. See post 16
03. Base to 8.4 Radio Conversion Harness (7 speed Fan specific models):
. . See below to make your own in standard or extended length
. . (or get one from: M² Mods )
NOTE: See Posts 6 & 7 (from 4spd conversion) for pictures of factory HVAC Module location using extended harness.
04. HVAC Control Module: 68268186Ax (AB, AC, etc) (7 speed Fan specific models)
** (also replaces 68183973Ax, 68236772Ax, etc. See here)
05. 911 Error Fix/Cell Bypass Plug: (or SharkFin Antenna mod)
. . See note 1 (below) to make your own or get one from M² Mods .
Quick Instruction Sheet References:
- 2013-2017 8.4 Conv for 7 Speed Fan Trucks 7-6-17.pdf
Shoot me a PM with your email/truck specifics and I can send you details on how to get a harness from us. It's basically plug n play for the conversion.
M² Mods - From my non Flammable S7!
