Kap1
Ex Ram 1500 2013 owner
- Nov 27, 2013
- 680
- 557
- 2022 Tundra
- 3.5 vvti
Hi All,
I just got my PPE pan installed onto my 2013 hemi 8 speed, it's at 105k miles right now. Truck was shifting very poorly and rough, now it's butter mooth like new!
1. The PPE pan for 8HP70 (part PPE228053020) did fit just fine to my stock 2013 hemi. Exhaust was not on the way of isntalling this pan. I searched all through the forums but couldn't get this confirmed for sure, but PPE tech support did confirm that it will fit.
2. I got the genuine zf lifeguard 8 fluid S671090312 $20 off ebay, and the new gastket for the pan: part 68172556AA. I drained almost 5 quarts of old dirty fluid, and pumped in almost 7 quarts (since the PPE pan adds 2 more quarts).
3. See the old fluid vs new fluid photo attached. Supposedly, my mechanic was supposed to change fluid at 50k... , but not filter, he charged me for 5 quarts of it. Seeing just how dirty the fluid is, i'm questioning if he really changed the fluid or not. I"m also a pretty mellow driver, not fast at all, and it scares me to see how terrible this fluid looks! I'm considering now to do another fluid change, since there was still about 4 quarts left in the transmission which you can't drain...
4. The fluid fill-up plug was extremely tight... i really struggled taking it off with the 3/8 ratchet lever from dewalt set i had. Also makes me wonder if my mechanic ever took it off to service it...
5. I researched all the guides on changing the filter pan/fluid, leveling truck, jacking up etc... but i still skipped one point where you have to drive it to 2nd gear (just couldn't do it as i jacked-up truck on 2x4's under tires to get level)
6. Those metal shavings and guuey sleeze/metal look pretty concerning. But oh well, life goes on, and thankfully transmission shifts very smoothly now.
Good luck to all !
Good luck to all !
