Bigskyroadglide
- Nov 9, 2016
- 1,329
- 2,078
- Location
- Montana, except for work
- 2014
- Hemi 5.7, supercharged
I find it interesting that many are skeptical of Ram's position that the 8HP series is good for lifetime, yet there's no skepticism of ZF recommendation for 80K fluid changes of their expensive, proprietary fluid. Seems to me that it's been just the opposite for ATF-4.
But I digress from my main point.
Recently I had scheduled to have the fluid and filter replaced in my ZF transmission as I was at the 75,000 mile mark. After the vehicle was taken in the transmission tech. approached me and asked if I was having an issue. I said "no" and that I was concerned about the condition of the fluid because of miles and because I tow about 7K, six or seven times a year.
He suggested that a health check be performed which would determine if there were any internal issues and verify the condition of the fluid. I said go ahead since I can't say I was anxious to spend the $900. He explained there were a number of checks performed with the scan tool that could determine the health of the fluid. I did specifically ask for a clutch index count, but he said there were four others that more directly analyze the fluid condition.
He came back later and gave me the condition report, as well as a small sample of the fluid. The fluid looked as green as the new stuff. So I declined the transmission service.
Later, I discovered online the recommended scan tool checks and thought I would share it with you: Gears Magazine - The ZF 8-Speed Transmission Fluid and Filter Change
Regards,
Dusty
2019 Ram 1500 Billet Silver Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 3 June 2018. Now at 78566 miles
I was wondering the same on fluid appearance. On several occasions I have read that fluid with 100,00 miles ( or thereabouts ) looked "just like new" or some description similar. My easily driven, never towed, 90% highway miles transmission fluid looked nothing like new fluid.or even close to new fluid at 58,000 miles. I must be doing something wrong.I had never head of the scan tool checks, that is interesting. I changed my fluid around 30k miles and it was very dark grey with pretty much 0 towing then, so I am surprised your fluid is still green. Maybe they keep a sample of new fluid around so they dont have to work on them? I am used to the old recommendation of 30k mile transmission fluid changes so a 60k to 80k interval on better fluid doesn't sound unreasonable to me.
Not only do I know the trans. tech. very well, but I watch what's going on through the service window. It was an honest sample that he took.I had never head of the scan tool checks, that is interesting. I changed my fluid around 30k miles and it was very dark grey with pretty much 0 towing then, so I am surprised your fluid is still green. Maybe they keep a sample of new fluid around so they dont have to work on them? I am used to the old recommendation of 30k mile transmission fluid changes so a 60k to 80k interval on better fluid doesn't sound unreasonable to me.
No argument on your description of your experience or the integrity of your dealership on my part. I certainly am not in a position to pass judgement. However, I am VERY surprised to read " The fluid looked as green as the new stuff." from a transmission that had 27,000 miles more than mine did when mine was serviced. And mine has never had a trailer hitch in the receiver. I sent a sample for a UOA on the transmission fluid. I anticipate that the report will be an acceptable one.Not only do I know the trans. tech. very well, but I watch what's going on through the service window. It was an honest sample that he took.
Besides, a dishonest tech. or dealership would be more motivated to upsell me.
Regards,
Dusty
2019 Ram 1500 Billet Silver Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 3 June 2018. Now at 78651 miles
Then it will be even more interesting to see what the UOA tells you. Please share it with us when you get the results.No argument on your description of your experience or the integrity of your dealership on my part. I certainly am not in a position to pass judgement. However, I am VERY surprised to read " The fluid looked as green as the new stuff." from a transmission that had 27,000 miles more than mine did when mine was serviced. And mine has never had a trailer hitch in the receiver. I sent a sample for a UOA on the transmission fluid. I anticipate that the report will be an acceptable one.
However, the fluid I sent certainly did not look as green ( or as clear ) as the new ZF 8 speed Lifeguard that was installed.
The Zip kit upgrade isn't as common in the Dodge world as it is in the BMW world,but it's probably not a bad upgrade.I looked into them a few years ago,but never got around to ordering one to try out.If you spring for it,let us know your thoughts on whether it's a worth while upgrade,as i'm still seriously considering it,but being in Canada and being a cheap bugger,i was sort of waiting to see if anybody would try it out before i spent the money on one,lolI'm also curious if anyone has ever done the shift improvement kit (zipkit) that Rock Auto sells that is supposed to help with shifting in general. My shifting isn't bad by my own experience but it could certainly be smoother.
You can see the information for these here:
I know many people upgrade older BMW valve bodies with these zip kits for their ZF trans.
Same here. It looks fairly straight forward with good directions but i'm not willing to learn about it on my truck.The Zip kit upgrade isn't as common in the Dodge world as it is in the BMW world,but it's probably not a bad upgrade.I looked into them a few years ago,but never got around to ordering one to try out.If you spring for it,let us know your thoughts on whether it's a worth while upgrade,as i'm still seriously considering it,but being in Canada and being a cheap bugger,i was sort of waiting to see if anybody would try it out before i spent the money on one,lol
I have no problem with trying it, if somebody sent me one,lolSame here. It looks fairly straight forward with good directions but i'm not willing to learn about it on my truck.
I'm just concerned I would screw it up and make a non-issue a real issue haha.I have no problem with trying it, if somebody sent me one,lol
https://alfaobd.com/ software along with a quality OBD reader...Do you have a good recommended scan tool that can see all transmission read data? so many to choose from on Amazon but I have no idea which ones are worth a damn or a good one to go with.
As can be seen I drew a sample at 45,200 miles. My plan was to do the pan/filter change at 60,000 miles. I was just curious as to what the difference might be in 15, 000 miles of further use. Various factors contributed to the pan/filter change being done sooner at 57,600 miles. There was as expected a pretty good accumulation of grey "******" on all four magnets. I have not cut the filter out yet to examine. Fluid was not clear green like what came from the bottles of ZF lifeguard 8 I used for replacement.Then it will be even more interesting to see what the UOA tells you. Please share it with us when you get the results.
Regards,
Dusty
2019 Ram 1500 Billet Silver Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 3 June 2018. Now at 78744 miles
