joesstripclub
- Dec 13, 2019
- 372
- 466
- Location
- Littleton, CO
- 2021
- Hemi 6.4
Did the mercedes van have the ZF 8 speed as well? What was the mileage on the pan you cut open from your truck? Fluid dirty I assume since the filter looks fairly grey?I finally got around to cutting the filter out of my old Pan. The last transmission service I did was on a Mercedes Van with the 5 Cyl. diesel. It was the first service at 30,000 miles. I was very surprised to see a ton of assembly junk and metal wear caught in the filter of the Mercedes. I mean a whole lot. That transmission was functioning perfectly at 76, 000 miles when I sold the vehicle. Compared to that experience what I found in the RAM transmission was almost nothing. I was surprised to see so little debris caught in the filter. As stated in my last post the magnets did have the usual grey fine sludge that I could wipe off with my fingers. If I passed another magnet near them I could get some "fuzz" to stand up. I don't think I would be eager to use an after market pan without magnets. JMO
The filter is made of some very tough and dense material. It is not thick but the material is very robust. You cannot tear it and it is difficult to cut.
I have seen questions regarding reusing the OEM drain plug. The plug does have wording and arrows for open and close. There is a torque Spec. stamped on the plug. It is an O-ring sealing mechanism. No crush or compression type of gasket. I was able to reinsert the plug and snug it without difficulty. For those who have contemplated a drain and fill if your plug is like mine I would imagine it could be done at least once. Note that it does say "open only" on the pan. The replacement Mopar / Filtran pan I used does NOT have a drain plug.
The few flecks of metal in the filter can be seen in the attached photos.
Edit: The straight cut seen in the filter is where I passed trough with the cut off wheel I was using to cut the interior filter / pan housing.
View attachment 505645View attachment 505644
I have a cheapy ebay pan that is actually a V6 part number. It came with magnets, but I believe the OEM magnets are fairly easy to remove and transfer to the new pan if not. Also I have drained mine 2 or 3 times and had no issue with leaks on the plug. I didn't know that was a issue people were having?
