8hp70 fluid
What fluid are you guying running in your 8hp70
  • Life guard/ mopar oem
    Votes: 23 48.9%
  • Amsoil
    Votes: 5 10.6%
  • Maxlife
    Votes: 18 38.3%
  • Mobil 1
    Votes: 1 2.1%
  • The bottle says atf
    Votes: 0 0.0%
  • Total voters
    47
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
In Synthetic Oil Thread owners were reporting good performance with Amsoil, but some had slippage with Red Line.
Don't recall reading anything about Valvoline.
I own a 66RFE trans, but like to keep up to date on newer components in event I upgrade.
Travis8352
Houghton michigan
Max life has been shown to be good in the zf8 and amsoil as well. Amsoil is all PAO. Another thats all PAO with a splash of ANs is HPL green cold climate ATF. Mobil 1 LV HP ATF looks to be a near perfect fit when compared to the lifeguard 8. It uses the same additive package as HPL but with GTL instead of PAO. Viscosity of the mobil 1 is only 0.1 cst off from lifeguard 8
HEMIMANN
Minneapolis, MN
Do you know what MaxLife is made of?
EdGs
FL
There have been several threads on here with members using Valvoline MaxLife in their ZF 8 speeds, and IIRC, all had great results.
You can get 1 gallon of MaxLife for about the same price as 1 quart the Mopar OE fluid, so definately a good value.
That said, if I had a warranty of any kind, I would be inclined to use only OE fluid and parts, so as to keep the warranty in effect. Pretty sure warranty would be voided once the red MaxLife fluid is seen, even though it seems to meet the spec of the ZF fluid.
One member in particular has 5 or 600k miles on his rig using the MaxLife. I am extremely tempted to give it a go on my next service.
Ram1683
Ram1683
Forked river NJ
I had found a thread on here, mightve been the same one. Guy running maxlife in 2 rams that are used for towing. Both has very high mileage with zero issues
Ram1683
Ram1683
Forked river NJ
That's hard to beat if it's just as good if not better then lifeguard
Ram1683
Ram1683
Forked river NJ
I have about 4500 miles on Max-life, 64000 on 2017 Ram 1500, so far couple 500 mile road trips and some daily driving, nothing stressful.
I went with PPE pan for a couple extra quarts of oil and perhaps better heat exchange.
No issues at all.
Seeing any difference in trans temp?
Ram1683
Ram1683
Forked river NJ
Well honestly having noticed any difference in anything, pressure, temp, it has been pretty cold here, going to be single digit highs this week.
That's damn cold. Do you still have the thermostatic valve and warmer hooked up?
ThunderMug95
North Prince George, VA
No issues at all.
Same set up here. Zero issue, but I’m only at sbout 450mi and will drain and refill one more time. I have one of Caulk’s bypasses, just havent installed.
txram956
