TC Retired
In hotter climates, change the fluid, or colder climates when you get a hard shift in the lower gears... But especially hotter climates.
You might be experiencing torque management if it's happening at WOT. Watch this short little video till the end where the car is on the track,and listen to the 2 -3 shift,my grandmother can double clutch a straight cut transmission faster then the car makes the 2-3 shift,lol.Of all things (2018) RAM, the one single thing I HATE, HATE, HATE is the shifting of my trans. Part throttle is fine, but WOT shifts, worse than rubber bands or hamsters running in a cage, are totally for crap. I am loath to spend $1200 for a new ECM, unlock, and tune just to fix it. Totally sucks to get on it and suffer from this crappy flaring issue...
Russ
Launching The 2019 Dodge Challenger R/T Scat Pack 1320
Jim Wilder, Vehicle Development Manager for Dodge Challenger SRT and Charger SRT, demonstrates drag strip launch technology in the 2019 Dodge Challenger R/T ...www.youtube.com
FWIW - I had my pan and fluid changed by a local shop at around 70k miles. I purchased online a factory Mopar pan and filter combo and 7 qrts of the ZF 8-speed fluid. The shop said they replaced about 6.5 qrts of the 7qrts I gave them. I immediately noticed a slightly different shift pattern after this, nothing drastic just different. After about 20k miles I finally jacked up the rear so the transmission body was level and crawled under. Following the instructions I downloaded from the ZF website I checked the fluid level. It turns out they had overfilled the trans by almost a full qrt. Draining some out to the correct level helped but I still wasn’t happy with how it felt. About 10k miles ago I crawled back under and used an electric suction pump I purchased off Amazon to suck out fluid via the fill hole. I was able to suck out about 4 qrts and replaced them with Pentosin’s ZF 8spd fluid purchased from Rock Auto. Just changing 4 qrts I noticed a huge improvement in the shifting. I’m getting ready to crawl back under and repeat the same process - suck out 4 qrts and replace with the Pentosin. We tow a small travel trailer through the Sierra Nevada’s so once I get about 8 more qrts of the Pentosin changed into it I’m planning to repeat this process at least once a year.
Curious to know if anyone else uses the Pentosin.
Yep cheap no name ebay pan and filter. Actually got the one for the v6 as it was only $30. I did have to buy a new gasket for it, so maybe $70 with a jug of maxlife as well. Been running for 20k miles with no issues. Drain plug even sealed after using it when I had to change the gasket.How do you do it for $60? The Pan and filter combo is more than that by itself! Unless your doing the cheap no name ebay brand pan.
Was the gasket defective or junk? I thought they wouldn't work great given the low low price of them.Yep cheap no name ebay pan and filter. Actually got the one for the v6 as it was only $30. I did have to buy a new gasket for it, so maybe $70 with a jug of maxlife as well. Been running for 20k miles with no issues. Drain plug even sealed after using it when I had to change the gasket.
