9006 Bulb Question
Buddhaman
Massachusetts
3.6 Pentastar
I have a 2014 Ram 1500 with the quad headlights(non-projector). The truck has the vertical fog lights, which use a 9006 bulb. I am changing over headlights and fogs to LED. Is there any reason why I cannot use a 9006 headlight bulb in the fog light housings?
KC Cryptkeeper
KCMO
2015 Ram1500
You can the beam will be different is the difference. Like a spot light compared to a flood light.
pacofortacos
A 9006 bulb is the same no matter where it is put.
If you notice the 9006 has a glare cap, do your LED's have a glare cap to prevent blinding for oncoming traffic?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Yours come with a 9145 in fog?
Graygoose
Oklahoma
Convert, for now.
small
Horizontal Fog Lights = 9145
Vertical Fog Lights = 9006
yes wasn't remembering when they changed , my 2011 had 9145's, my 2015 had vertical, wasn't sure on 2014's
Alla Lighting LED
14722 Yorba Ct, Chino CA 91710
RAM 1500
headlight bulb sizes is different fog lights, for vertical shape fog lens, fog light bulb size is 9006, for horizontal fog lens, bulb sizes is H10 9145, for headlight bulb sizes guide below:
  • for 2011-2012 Ram 1500 w/2 headlamps (Dual high and low beam headlights bulbs): H13 headlight bulb
  • for 2011-2012 Ram 1500 w/4 headlamps (High beam bulbs are separate with low beam bulbs):
Ram 1500 high beam headlight bulbs: HB3 9005 headlight bulb
Ram 1500 low beam headlight bulbs: H11 headlight bulb
  • for 2013-2021 Ram 1500 headlights bulbs:
High beam headlight bulbs( for the high beam with halogen headlamps): HB3 9005 headlight bulb
  • for 2013-2016 Ram 1500 headlights bulbs:
Low beam headlight bulbs (for the vehicle with projector-type headlamps): HIR2 9012 headlight bulb
Low beam headlight bulbs (for the vehicle without projector-type headlamps): H11 headlight bulb
  • for 2017-2018 Ram 1500 headlights bulbs:
Low beam headlight bulbs (for the vehicle with projector-type headlamps): 9005HL+ headlight bulb
  • for 2019-2021 Ram 1500 headlights bulbs: Low beam headlight bulbs (for the vehicle with halogen capsule headlamps): H11 headlight bulb
Cableman
Longisland
Im using 9006 morimoto 2stokes in my vertical fogs, when going to led 9005/9006 is the same.
Ddm sent me 9005s and they also fit in the 9006 housing but weren't clockable so i pulled them.
