91 Dodge Ram build
yuriromanov27
318 small block
Okay so.. I need some help. I'm a little stuck on wiring my dodge.
I've been building this truck from parts off of two other Rams. only one headlight is shining at the moment, and now I have a misfire in 2 cylinders. I've checked the compression and spark, and both of those are good. I thought it could be a fuel issue because the fuel pump came from a v6 dodge Dakota. Any suggestions?
kg93
AZ
wrong section, post or get this moved to the 1st gen section
Y
yuriromanov27
318 small block
Alright thanks
