Tartmonkey22
Hello all, new to the forum. I just purchased a 95 2500 with the 5.9 and 4x4. Motor runs great. Trans has some issue. It has the 46rh in it. And while I find lots of threads on the 46re not many for mine. The truck has just about 180k on it. The trans had a full rebuild at 176k but thst was back in 2006, so no warrantee on it. It sat for a year before i bought it with only being started here and there to move it around a storage shed.
Issue I'm having is it seems to shift through the first 3 gears fairly quickly, but not past that. Even in third gear I am limited to around 30 mph and I am up to 4000 rpm. OD button lights up when pushed but nothing else happens. I've added fluid to it with no diffrence. Reverse works fine. Any ideas or suggestions?
