Moving more air volume over the transfer point of heat/cold may not help at all. The transfer is more efficient with a larger surface area and at a certain volume flow, increasing velocity of airflow reduces efficiency if surface area remains the same.
You may have low pressure in your system that is impacting your A/C, bad thermostat impacting heat, etc. If you have zones it is possible the process of shifting airflow or the temperature control is not working properly. Make sure the whole system is functioning properly before replacing parts of it. You can also do things like tinted windows to help. Good luck
