a pilllar gauges for gen 4 trucks
autobred
southern md
sold* 10' R/T..13' R/T
just wanted to share some part #s for gauge pods if anyone is interested in installing some. They are made by Gauge Works/Autometer.. part #17219 for 3 pod, #17218 for 2 pod. You will not find it in the autometer website, they are still in trial phase. Color is taupe slight shade off when compared to side by side with oem but once installed you cant hardly tell looking from left pillar to the right. If searching..these are spec. out for a 2010 diesel ram so I wasnt sure till I bought them and tested and they fit great.:)
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Great info, what gauges are you going to run in your truck and did you go for the dual or triple pod?
autobred
autobred
southern md
I went with the wide band A/F meter sport comp pro, 0-100 psi fuel pressure sport comp 11, vac/boost sport comp 11 models..I tried to match them with the black faces of our oem gauges. I thought the white dials look better though. Set them up to dim with factory gauges. I was adjusting parameters blind last fall for track conditions, promised myself I would try not to do that this year LOL
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Sounds good, yeah adjusting blind is deff hit or miss.
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
looks great!
OklaHemi
new age hemi
where have you been ron?
Copperhead
Chesapeake, VA
Not that active on here..... or anywhere that much anymore. I am still working on the garage (electrical almost done and insulation about a third of the way) and making modding plans before the Spring show season starts. :D
xpst500
CA
2011 4X4 QC SB BIG HORN
Thanks for the info!
09 RAM RT
very nice! :D
Jacqson
N. Vancouver, BC
Looks great but do you have any problems with the gauges blocking any outside views from inside the truck?
1Popeye
