A904 questions
MindlessMopar
Missouri
3.7 slant six
Hey everyone I’ve got an 84 d150 with the slant in it. I recently had to pull the transmission back and replace the flex plate as it was bent and causing vibrations. It caused some damage to the input shaft and is still leaking after a new seal. Do you guys think if I pull the front pump replace the bushing, the gasket and the seal again would it stop or do I need to start looking for a replacement 904? It’s starting to get hard to find these slant six transmissions.IMG_2467.jpeg
