Jstop11
I have a 2015 Ram 1500 quad cab Tradesmen, 5.7 Hemi, 6 speed, 3.55 with ~50k. Over the past year I have lost my trailer brakes 3 times.
The first time there was a wiring issue with my TT that I have since had checked out and fixed. This event did not cause any ABS faults.
the last two event have thrown ABS faults first, listed below, causing disabling ABS, Traction Control, and the Trailer breaks. I was still able to manually apply the trailer breaks from break controller. the two events happened on separate trips but once I got to my designation and unhooked for the night the ABS Faults went away. They did not come back at all the rest of the trip. I only have had the ABS faults while towing.
Does any one have a clue of the issue that could be causing the faults?
Faults:
C0037-1D Left Rear Wheel Speed Sensor-Circuit Current Out of Range
C0037-2F Left Rear Wheel Speed Sensor-Signal Erratic
U0415 Invalid Data Received from Anti-Lock Brake System (ABS) Control Module "A"
U0415-00 Implausible Data Received from ABS
Faults:
