ABS nightmare. Previous owner cut the ABS wire
Emmadoll25
waterdown
New member here. Any help would be greatly appreciated. Recently purchased a 2008 dodge ram 1500 as a winter truck so my 2nd generation mint dually can stay inside. ABS light was on when I purchased, but it clearly needed a wheel bearing and my mechanic suggested that is all it would be in most cases. Turns out the 1st owner of the truck cut the ABS wire somewhere past the inner fender. I cannot find the other end of the wire for the life of me. Does anyone know where it ends up going? Thank you for any info!!!
powerhour
Clearwater County, Alberta
2005 and 2019 Classic
5.9 CTD and 5.7 Hemi
You can follow the abs wire on the opposite side and it will go to the abs module by your brake reservoir
