AC freon leaking out of high side schrader valve.
souperbee
North Florida
5.9 gas
I have a 2001 Dodge Ram 2500 quad cab with a 5.9 gas engine. My schrader valve on the high side is leaking. Can you tell me if I have to replace the high side line in order to replace the schrader valve or is there a way of taking it out without replacing the line . Please go into detail if it is replacable.The schrader valve the parts house gave me is bigger than the hole where the schrader valve screws into. Please reply ASAP! I live in Florida and it is still in the 90's. Thank you
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
Honestly go to an AC shop. You can get away with just the valve they fail all the time.
This happened on my 2007 Jeep liberty, they replaced the valve and recharged the system for around $80.
txtrucker75
You can buy just the schrader valves at any parts store and replace them yourself a lot cheaper than taking it to a shop and letting them do it.
WilliamS
Tampa FL
You can change that part in less than a minute. As for vac the system down and refill is a different story. I wouldnt refill unless you can pull the air out first. Sure it would work with those autzone cans, but the water in the air here in florida will slowly corrode the guts of your gear.
