Ac vent problem
gwolf
Tucson, Az.
Magnum 5.9L
I havent posted on here in a very long time, I have had another side project that i have been working on. but any who, here is my problem:
When I have my AC on it blows through the vents as normal, but when i push on the gas and accelrate as any speed, light or hard, the vents switch to my defroster, and when i let go of the gas or just pushing the pedal to maintan speed it switchs back to the normal vents and a loud thud noise happens.
Any ideas on what this can be and how do i fix it?
Sounds like you have a vacuum leak or the check valve is bad. The thump is probably the actuator door slamming open.
Someone else on this forum posted a similar issue. I had the same thing happen to a different vehicle.
gwolf
gwolf
Tucson, Az.
Magnum 5.9L
what valve are you talking about?
there is a check valve that keeps the vacuum cylinder in a vacuum when you accelerate.
gwolf
gwolf
Tucson, Az.
Magnum 5.9L
that might be the problem, becuase my CC doesnt work as well
Swoosher
5.2L
Vacuum leak, my truck is doing the same thing. I have a leak in the CC system I need to fix.
rod7515
On mine there is a vacuum canister (small plastic Box) that stores vacuum for when engine vacuum is low due to acceleration. It was located under the passenger side windshield area under the cowl.
Rod
DUCKY1090
