Acceleration issue
Zamboni
I am having troubles accelerating my 2012 ram 2500 hemi 5.7 L. The problem feels like it is running out of fuel and only happens the first time I start the truck everyday. Fuel injector cleaner seemed to help at first but it is now getting worse. It seems to be worse in colder weather. There is no engine light on so I can't use my code reader. Any idea on what could cause this? Thanks
PCT
2019 2500 6.4
Northern California
If its under Warranty i would take it in, my 97 Ram did this before the fuel pump died, i know that a different truck be could be a sign the fuel pump is going out
Kotta390
Could be a fuel pump related issue. Take it in and have them diagnose for a check valve problem on the fuel pump. It could be losing its' prime overnight, but normally if the fuel pump is fine and the check valve is bad, it will only be an issue for the first 10-15 seconds at most.
Try turning your truck key to the on and off position 2-3 times before you actually start the truck and see if that makes a difference.
