Ricks Ram
- May 1, 2015
- 4,411
- 3,388
- 2014
- Hemi 5.7
Glad you got it all done. I'm also glad someone else gave it a try because it's really not that difficult. Both of our boxes had a small crack on the front mounting tab because of the way they are packed. I used JB plastic weld on mine and it worked fine to fix it. Where mine was cracked really wasn't an important mounting point and neither was #STecoD's. If I'm looking at the picture of yours correctly it looks like yours had s much larger crack than ours did.Sunday, HVAC box installation continues. I had to wire the connectors as describe by @STecoD and connect the actuator.View attachment 177174View attachment 177173 It would have been better if I had drained the coolant rather than pinch the hoses it was just a matter of clean up.
Reversed the order of things and installed the box and panel. Actuator movement tested successfully. I will recharge the A/C system later today and fully test the system.View attachment 177175
