Seabee67
Just bought a used 2002 Ram. It didn't come with factory installed fog lights, just the louvers in the "holes" of the front bumper. When inspecting the truck when I first bought it I noticed a wiring harness in the area of the driver side hole that would be for that fog light. I looked online and found a jumper harness kit that looked like it would fit the existing wire end. There is a fuse in the spot for the fog light in the fuse box. Also, online I found a headlight switch replacement that is identical to the one I have except it has the fog light feature. Apparently you just push the headlight swith to turn them on/off.
My Questions-
-I haven't had a chance to look behind the existing switch to see, but does anyone KNOW if the other wiring is there to connect to the new switch?
-Any recomendations on fog lamps or kits that fit well to the existing factory bumper?
-Any words of advise?
Thanks
My Questions-
Thanks
