Adding Fog Lights to 2021 Ram 1500 Classic Warlock
Nor05
Mechanicsburg, PA
5.7 V8 Hemi
Hello all,
I am new to this Forum and this is my first truck purchase. I have a 2021 Ram 1500 Classic Warlock and would like to add fog lights to the truck.
I called the dealer and they said MOPAR doesn't have any kits for my DS truck so they are not able to install them.
Does anyone know if this is possible and if so what parts I would need to get?
Thanks!
Ron
Ricks Ram
Hello all,
Thanks!
Ron
Yes, it's possible. Contact @M2mods in the vendor section of the forum. Besides installing the fog lights you will need a new switch, factory fog light harness plus Jumper Harness from M2mods. You will also need to enable the codes with the Alfa Tool. There is a full writeup on it in the 4th gen DIY section. Since your truck is a Classic it's considered a 4th gen.
Sent from my SM-G981U1 using Tapatalk
Nor05
Nor05
Mechanicsburg, PA
5.7 V8 Hemi
Thanks a lot for the help guys. This has definitely been a project. I think all I need now is the jumper harness.
Wulf
United States
I would think that since the truck CAN be ordered from the dealer with factory fog lights, the dealer saying "we can't do that", sounds like BS. Although, going through them would probably be outrageous on the price anyway.
BTW, that front view looks a lot like mine. Except for the Hydro Blue mine is wearing. Same projector headlights, blacked out bumper/grill, good looking truck.
ShowMac
Pennsylvania
PennStar 3.6
Bump wondering if you got this figured out just got a warlock myself today love it except no fogs I can run an accessory harness relay style but was hoping to see about a mounting solution.
Wulf
United States
I am in the process (years in the making probably) of getting my truck to be more, well, my truck. Going to be looking in the 4th gen section tho, as the "Classic"s are considered 4th Gen, not 5th.
Jennkelly
Dedham MA
V6
Hello all,
Thanks!
Ron
Did you ever get a kit for your truck? I have the same truck and looking to installing one
ntmd8r03
Colorado Springs
The parts on this list should be every thing you need.
68271564AA Bumper Bezel Kit
68466268AB Fog Lamp (x2)
68269912AA Headlamp Switch
68271557AA Front Fascia Wiring
68272016AA Hex Head Bolt x8
68272023AA U Type Clip x8
plus
Fog Light Harness from https://www.m2mods4ram.com/
juang
markham
朋友,你的雾灯增加成功了吗?
michaelw31
NJ
3.6L
How do you actually install the lights themselves? Did you remove the lower bumper or did you work your way through the wheel well?
I removed the grill and saw what appeared to be mounting brackets behind the bumper but I had no way of getting in there. It seems to me installing the lights will be more daunting than wiring them.
Dave Haddon
Saskatoon SK. Canada
Another new Warlock owner with no Fog Lights...are the parts you listed the ones we order from our Parts Dept at the local Ram dealership?..but the harness has to come from m2mods4ram...is that correct?
Mb7640
Fountian hills az
plus
Your list helped me a lot. Expect the harness was wrong but I made it work
jeanbacan
Alberta, CA
V8
After searching about the fog lights and reading everything, Im a bit confused. Will these work or not?
It seems what @ntmd8r03 used right? does the Bulbs connected to the plus?
Dave Haddon
Spoke to Seerice Mgr..good guy..said no problem seeing as how I am wiring them to a dash toggle switch. He could arrange to remove trim bezels, put in appropriate ones for round Fog lights and run wire to the toggle switch..about 1 hr work...seems reasonable...will keep you updated.
tron67j
Maryland
The install with the factory switch instead of an auxiliary switch, if you go that route, requires the harness from M²Mods. It was pretty easy, I did same thing, and made it easier to use them as button is now part of the light switch. For me, looking more stick was also a big reason to not use the auxiliary. Plus. With AlphaOBD you can change settings to have figs on with high beams, which was huge for me as I drive on dirt road a lot.
Dave Haddon
Has anyone removed the bezel that covers the fog light "to be" area? Would it be correct to say you remove the tires, and access the bezel from behind? Perhaps remove a portion of the wheel well liner? have not found any video on this for the Warlock/DS version of the Ram 1500..going blind...will video myself if none already out there...thanks
ShowMac
Pennsylvania
PennStar 3.6
If anyone can help I tried wiring these to lights to a relay harness and got no power to etiher light on two different relay harnesses. Power straight to each and came right on. I'm assuming maybe something with a canbus or decoder possibly built into these fog lights. At this point I am planning to go the OEM switch route. What other wiring would I need besides the front fascia wiring oem harness? Or just that and the switch or do I need something from M2 mods.
