CalDad14
- Jun 9, 2021
- 30
- 16
- Location
- Calgary, Alberta, Canada
- 2017 Ram 1500 Crew Cab, 4x4, 6-speed, short bed, 392gears
- 5.7
2017 Ram 1500 SLT, 5.7, 6-speed, 4×4, CC, SB, 3.92Gears, Camper Shell(Canopy). Bone Stock! Just over 32,000kms.
Purchased truck brand new, March 2017. My ride quality has really declined over the last 12 - 14 months. Confident that it's the tires(original, from factory). Possible rear sway bar bushing is worn.
Currently shopping for new tires. Would like to lift the truck then get tires. Not trying to run the Baja or conquer Moab. My FIL has 2007 PW, my BIL has 2013 PW. So, I have a little bit of "keeping up with the PW's" going on!
We do summer camping where I tow a small camper(<5000lbs), tackle the occasional trail, harvest trees, haul water. We also do winter picnics.
Don't have a ton of $ to spend. Would like to keep it under $5,000.00 CA. including install.
Want to go 4" lift max. Give me a bit more clearance along with some piece of mind in the snow. You never know what lies just beneath that fluffy white stuff! I'd like to use my stock 17" rims as well.
I've had a couple sit downs with some off-road shops in town. I get different answers/recommendations from each place. 33"'s will look goofy w/a 4" lift, if I do a full "lift kit" then I need to upgrade my hubs too, etc???.... Even got an estimate from the dealership I bought the truck from and the cost was astronomical, >$12,000.00!!!
Again, I'd like to lift the rear 2" - 3", then match the front. I'd like to keep the "geometry" of my truck as true as possible. I know once I "lift" my truck it won't ever be perfect, but I'd like to try. I'd like new/upgraded struts & shocks. Possibly HD coils(when I tow, I'm usually maxed out on my "payload capacity"). I'd also like to replace/upgrade all bushings in regards to the steering & suspension. I'd like to run a 33" × 12.50 on my factory 17" rims.
I've researched AEV. They seem to focus their efforts toward Chrysler products, which I like. For every good thing I hear about Fab tech, ask a different "specialists" and they'll tell you everything bad about it!?!
If someone smarter than me might be able to provide some ideas? Give me a starting point with the basics of what I'm after. I would really appreciate it. Thanks to all.
