Timeless
- Feb 13, 2015
- 210
- 80
- Location
- South Carolina
- 2019
- 5.7 Hemi
Cooler temps are the only thing ags delete helps. Less strain on the water pump if you do the v6 fan as well and reduced rotating mass on the engine. Cooler temps are good for tuning. More life out of the water pump And less rotating mass means peppier acceleration with the v6 fan
Edit. In simple terms the ags helps to reduce engine temps and that gives room for tuning abilities. Also with ags delete you are less likely to end up with heat soak in the engine bay
So my understanding was the AGS would open if cooling was necessary?
