SoulFish
Just wondering if anyone has installed air bags in the rear for towing in a 2020 PR. If so would it allow you to tow higher loads? Keeping in mind you would deflate them when not towing.
I hope your wearing a fire suit because the Payload Police are gonna burn you alive thinking you can tow over what your payload sticker will allow.Just wondering if anyone has installed air bags in the rear for towing in a 2020 PR. If so would it allow you to tow higher loads? Keeping in mind you would deflate them when not towing.
A PowerWagon has a softer suspension to be more off road capable, that lowers the "sticker" towing capacity. The truck's axles, brakes, frame, etc. are the same as any other 2500. Adding airbags will help with the rear end squat but you'll still want to use a WDH.
I’m comfortable towing my toyhauler! Fully loaded with RZR, H2O, gear, clothes, food, dog...@11,500+/-!
Bags at 45psi, 12,000lb Equilizer WDH!
Driven in high winds, torrential rain, heavy traffic! Drive accordingly, be vigilant and situationally aware!
View attachment 245600 View attachment 245601 View attachment 245602
Sorry for the lack of actual part numbers!
Right after I ordered my truck, I found a local guy selling his Timber Grove airbags from his Power Wagon. They are the 2" longer version. I looked at them and decided I didn't want to mount the brackets on the bottom since I thought they would rip or cause restrictions with the rear axle articulation. So, I bought the Daystar cradles and used those instead on the axle itself. They seem to work well and I haven't had any significant issues. I haven't towed yet (we will next week), but I have no doubt that they will work fine.Update: turns out that Airlift doesn’t make a universal kit with bags long enough for Natasha’s rear coils. Totally unloaded the inside distance top to bottom is about 13” (inside width is a hair over 5.5”). Does anyone know of a company that makes airbags for the Power Wagon? Thanks.
