tunedlaramie
Hey, what's up. My 09 Ram Laramie's air condition is acting weird. When I start my truck up it blows for a few seconds the way it should, then it almost stops blowing no matter how the knop is turned. Then after about six minutes suddenly starts blowing again and from there on I can control the AC until I shut the truck off. Also the passenger side only blows cold and the drivers side can be controlled but both sides don't cool as much as they should. Freon level is good though.
Also, I just replaced one blend door actuator that was knocking but there is still one knocking a bit but this one is behind the dashboard.
Any ideas on what the problem might be?
Thanks
Sent from my SM-N960U1 using Tapatalk
Thanks
