Air Condition
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
So, lately my AC has been deciding when and when it didn't want to work. So today it stopped again. I looked under the hood, and the whole can and all metal lines leading from it were covered in ice. This ice immediately started melting, but everything was white for a minute or so. What could cause these things?
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
No heat either. Bleh. It's too hot for this. Lol. The whole can immediately starts freezing if the AC is on and the trucks running. Nothing happens at all on accessory mode.
rambob
LA/MS
318 5.2l
with home a/c units, it usually means the freon is low.
but I really don't know about the auto system.
txbass06
NE Texas
5.9 Magnum
Low freon could be the cause? Is your compressor short cycling?
Sent from my iPhone 4 using Tapatalk
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Not sure. The compressor Pulley is still turning. And not sure why it's freezing it up.
txbass06
NE Texas
5.9 Magnum
You'd hear it if the compressor was doing it. I'd take it somewhere and have the freon level checked to make sure that isn't the problem first
HKkid
Missouri
Have you tried adding freon to the system?
ramhunter9
P-Star Jeep Wrangler
Your comp pully will run all the time . check your AC clutch fan ... does it turn on and off
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Which one is the AC clutch fan?
ramhunter9
the fan right in front of the fuse box and battery
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Oh. Haha. I'll check it in a second.
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
The AC clutch fan is on. Full speed it feels like. Lol. Very temperamental. It's on now, then I turned off and on quickly. Turned off, did it again, worked again
quietpeen
2021 TRX
Hellcat
i agree to check the freon
ramhunter9
Well could be a leak and low on freon
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Where is the low pressure port on my truck?
Is it the one on the black canister, or the one in front of and on top of the radiator?
txbass06
NE Texas
5.9 Magnum
IIRC, it's the one on your accumulator, the black canister near the firewall on the passenger. If you're adding the freon yourself, the hose will only fit over the low side port
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Awesome. Thanks!
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
So, reading through a Automotive maintenance book today, the symptoms of my AC seems to be a partially clogged condenser canister. The AC stopped working again today. I popped the hood, tapped the outlet line off the condenser with the end of a ratchet, and it started working again. So, my guess is something is in there getting in the right position sometimes to slightly clog it up.
