Driving in Iowa in the middle of winter on ice, lower the pressure if you want to stay out of the ditches. Lots of hearsay about handling and blowing a tire from low pressure. When you can't drive over 45mph without sliding off the road tire pressure makes a huge difference.
Why do tires have a max pressure and not a minimum pressure? My jeep has 15psi in the tires right now, chalk test says pressure is perfect for 35s and 3000lbs. I know we are talking 2500 so yes the pressure will be higher, just not as high as people think. My work rigs are 3/4 ton truck used on mine sites in the middle of nowhere, I run 30-35 psi year around to keep from beating the driver to death off-road. I have dropped the tires to 20psi in winter while commuting from Carlin NV to Los Angeles. Only time I would go up pressure was when trailering or quick change oil kids filled up the tires.
