Funkadelic
This winter I have had an issue with the airbag light coming on intermittently in my 2003 Ram. Some days it doesn't light up, other days it lights up and chimes off and on the entire time I drive it. This past fall I removed the dash to replace the heater core and evap core. My first thought was the wiring harness to the airbag controller came unplugged under the dash. Checked it and plugged in ok. Then I took off the steering column cover to chech the wire plugs for the clockspring. No issues with plugs there.
Not sure if the dealership can pinpoint the issue by scanning the airbag light code (if it happens to be on when I drop it off). Are the only areas that seem to go bad are the airbag controller and the clockspring? Any other suggestions?
