Alfaobd question
BlackGrizzly
So about a week ago I installed a small airhorn behind the grill. I zip ties the compressor to what I know now is a air flow regulator. Small vents that move up and down. So it made my check engine light come on. I took it to the dealership to pull code and replace if needed. Of course the want to charge me a $1000. I removed the air horn and the vents are moving. Seems like they tried to hustle me. Anyways the damn check engine light is still on. How do I clear faults with alfaobd? Maybe now that I freed up it will clear. Thanks guys
1500ram12
5.9L Cummins
Connect to the correct engine on the main screen. Then click on the check engine symbol. And clear codes. Wouldn't hurt to check the bcm also
2018 Ram 2500 6.4L Hemi Tradesman
y1500l
tampa
can someone tell me if we can tune the throttler body to be more responsive with alfaobd
1500ram12
5.9L Cummins
No. To get better throttle response you'll either need a tuner that can adjustable throttle sensitivity or a throttle booster like pedal commander
2018 2500 6.4L Hemi Tradesman
Lildikgang
Houston
Could I program a fob to my with this my truck came with metal keys from factory and dealer is saying I can’t do this I don’t like my metal keys and would rather have a fob instead
vitbvc
