Help Support Ram Forum by donating:
AlfaOBD
Discussion in '4th Gen DIY' started by Ghost_RAM, Jul 30, 2018.
  1. SitKneelBend
    SitKneelBend Senior Member
    5,307
    2,082
    Jan 8, 2015
    St. Louis
    Ram Year:
    Engine:
    3.6 Pentastar
    Maybe, I'm only guessing right now as they are labeled generally the same and pinned generally the same as the AUX left/right inputs.
    [​IMG]
  2. crf250pilot
    crf250pilot Junior Member
    50
    Nov 12, 2019
    oregon
    Ram Year:
    Engine:
    hemi 5.7l
    Just got the alfaobd going for my 2014 sport with factory led tail lights. I’ve been trying to disable rear turn signal dtc monitoring to get rid of the “ rear left turn signal out” evic message. Got several other features to work. Does anyone know if there is even an option for this? I can’t Stand the dinging every time I hit my brakes anymore. Ready to to trade this thing in already.
  3. chrisbh17
    chrisbh17 Senior Member
    5,492
    5,525
    Oct 12, 2017
    Ram Year:
    Engine:
    Not sure that's an option on the 2014......I think it started in 2015.
    Your best bet is probably a load resistor.
    I did read there might be a wire that you can jump to ground that might do the same as the Alfa option, but it's unclear if it is on a 1500 (the reference I found talks mostly about 2500 and higher)
    Sent from my Pixel 3 XL using Tapatalk
  4. nitewatcher769
    nitewatcher769 Junior Member
    50
    Nov 13, 2016
    Ram Year:
    Don't have
    Engine:
    Eco-diesel
    I have a question. I have gotten a hold of a 7 cluster and installed I noticed it’s all in miles and Fahrenheit, I am in Canada and the truck it was pulled from was from Canada as well. I have all the info from the wrecked truck and it’s all in km’s and Celsius.. is there a way to put back to km’s and Celsius. Both trucks are 2014 mine is a SLT and other I don’t have the trim line on it but have the vin.
  5. MrDazana
    MrDazana Member
    33
    Jan 19, 2017
    Ram Year:
    Engine:
    What does it say in uconnect under settings/display? have you tried swapping it to metric/imp ?
  6. crf250pilot
    50
    Nov 12, 2019
    oregon
    Ram Year:
    Engine:
    hemi 5.7l
  7. crf250pilot
    50
    Nov 12, 2019
    oregon
    Ram Year:
    Engine:
    hemi 5.7l
    Chrisbh17, thanks for the input. I was thinking of adding a load resistor also. Not sure which color wire goes to the left rear turn signal. Does anybody have a tail light wire diagram or color code. Thanks again
  8. diboblo
    diboblo Member
    52
    89
    36
    Mar 12, 2019
    California
    Ram Year:
    Engine:
    6.2
    Left and right.
    Premium and base.
    2014 RAM 1500:
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Bob
  9. crf250pilot
    50
    Nov 12, 2019
    oregon
    Ram Year:
    Engine:
    hemi 5.7l
    Diboblo, you guys are awesome! Thanks so much. Got a couple load resistors on the way. Will keep posted if it helps.
  10. SitKneelBend
    5,307
    2,082
    Jan 8, 2015
    St. Louis
    Ram Year:
    Engine:
    3.6 Pentastar
    Victory! Now I just need to swap pins and see if it plays audio...
    [​IMG]
    1500ram12, mtnrider, Mpgrimm2 and 2 others like this.
Share This Page
