Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
AlfaOBD
Discussion in '4th Gen DIY' started by Ghost_RAM, Jul 30, 2018.
  1. TX3500
    TX3500 Junior Member
    43
    14
    Mar 28, 2020
    Spring
    Ram Year:
    Engine:
    6.7CTD
    Esc. Been on every since I swapped to a g56 file. I’ve been able to cure everything but this. According to alpha there’s no call/signal for it to be on.
  2. Michael Butts
    Michael Butts Junior Member
    37
    10
    Oct 19, 2019
    Indiana
    Ram Year:
    Engine:
    I got the issue fix. Had to make sure the three tpms features was on.
  3. iCanuck
    iCanuck Junior Member
    34
    8
    Jan 17, 2020
    Vancouver, BC
    Ram Year:
    Engine:
    Can someone please provide me with a 2013 Ram 1500 5.7L 2WD BCM Configuration. There is a 2018 4X2 config in with the Shared Configs but the layout of it isn't right and you can't compare with it.
    I would prefer 2013 but any 2WD would be helpful.
    Thanks in advance.
  4. eyerish
    eyerish Junior Member
    Jul 24, 2017
    Ram Year:
    Engine:
    Hopefully I didn't screw this up too badly.
    Got a little rambunctious last night when my AEV cable arrived. Programmed new tire sizes, which seemed to go fine. Then moved on to programming the BCU with new TPMS thresholds. Got to the next step in the process and realized I failed to get the 4 digit pin from my dealer. Went to drive the truck this morning and I've got all sorts of dash lights going:
    Check engine
    Service ABS
    Parksense front and rear off
    Service trailer brake
    Service electronic throttle
    I made it to the dealer, got the code and did the RFH reset procedure and it took fine. The problem is the lights are all still on. I've attempted to use AlfaOBD to reset any codes, but they keep returning.
    I've also started the whole process over. Program BCU, wait, Reset RFH, wait. Lights persist.
    Any help would be greatly appreciated.
    Thanks!
  5. chrisbh17
    chrisbh17 Senior Member
    6,021
    6,436
    Oct 12, 2017
    Ram Year:
    Engine:
    Ive had this happen once or twice. Its like the codes get "stuck" somewhere.
    IIRC what fixed mine was going into each individual module (BCM, ABS, etc) and resetting the codes inside each module. And my thinking is that is how its supposed to work....there is no "erase all" that goes into each module and erases them all at once.
    There is another app that will do that, but in reality all it does is connect to one module at a time and erase all codes in that module.
    1500ram12 likes this.
  6. Jimmy07
    Jimmy07 Senior Member
    2,532
    1,967
    Feb 23, 2017
    Ram Year:
    Engine:
    Did you perform the ABS initialization after you were done programming the tire size?
  7. eyerish
    Jul 24, 2017
    Ram Year:
    Engine:
    Thanks Chris. I was still sitting in the dealership parking lot and attempted just what you had described (although I didn't go into every module, I just went into the ABS module). Once I reset that, it seemed to clear all of the other lights. I drove the 35 miles to work without issue and the lights have stayed out. Appreciate you response.
  8. eyerish
    Jul 24, 2017
    Ram Year:
    Engine:
    I did not. Probably another case of me not looking into it enough. Two or three of the videos I watched on youtube about it don't seem to indicate anything about performing an ABS initialization. I'll go back to the OP and check that out. Thanks.
  9. 1500ram12
    1500ram12 Senior Member
    5,008
    1,844
    Jan 23, 2012
    Ram Year:
    Engine:
    6.4L Hemi
    Step by step instructions in here
    https://drive.google.com/drive/folders/1xQvdHVTgRwKQRKSBh1K2rkCqg5dlpSi0
    2018 2500 6.4L Hemi Tradesman
  10. HoustonBussa
    HoustonBussa Junior Member
    47
    May 17, 2020
    Houston
    Ram Year:
    Engine:
    Adding Fobiks.
    How long does it take to program a key? (Mine is still saying please wait after 10 mins).
    I'm trying to add two new ones. Do I have to disassociate the old one? (Is there a limit, etc)
Share This Page
