Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
AlfaOBD
Discussion in '4th Gen DIY' started by Ghost_RAM, Jul 30, 2018.
  1. likes2build
    likes2build Senior Member
    1,149
    1,055
    Jun 12, 2018
    Mohawk Valley, NY
    Ram Year:
    2018 Express RCSB
    Engine:
    3.6 Pentastar
    I have some thoughts on this. @Mpgrimm2 I told you what happened last weekend that I had changed the vehicle line by accident when accessing the radio module. The fuel gauge went to empty, the cluster lit up like a Christmas tree with needles bouncing side to side and showed a traction control failure. Yes I was quickly able to fix the error but it sure was a pucker up moment.
    Mpgrimm2 and SitKneelBend like this.
  2. wickedswede
    wickedswede Junior Member
    38
    Mar 16, 2021
    Avesta
    Ram Year:
    Engine:
    cummins
    Hi,
    I bought the obdmx+ alfaobd software, main reason to be able to set my speed limiter at 90km/h on my 2015 ram 2500 cummins.
    But I cant get it to work.
    If I go to engine and to speed limit . It says max value to set is 0km/h and minium 40mph.
    means there is no acceptle value,, I have tried with 90 but all it says is that its not a value in the correct range.
    (i can set top speed on cruise control with sucess)
    Also tried to go to the bodycontrol module where you can set max speed 0-500kmh.
    I set it to 90kmh and it accepts and new value is 90,000.
    But in real life,, there isnt any speed limiter at 90kmh.
    How should I do to make this work?
  3. wickedswede
    38
    Mar 16, 2021
    Avesta
    Ram Year:
    Engine:
    cummins
  4. Joji91
    Joji91 Senior Member
    29
    298
    57
    Jul 31, 2016
    Ram Year:
    Engine:
    Can you see the times and other stuff still?
    Sent from my SM-N986U using Tapatalk
  5. Rock$tar
    Rock$tar Senior Member
    33
    125
    21
    Jan 3, 2013
    Newfoundland, Canada
    Ram Year:
    Engine:
    Cummins 6.7L
    Guys on Facebook at it fully working. And after got it worked changed vehicle back to DS ram and the pages stayed. Even reset BCM and if stayed. So curious to see how long it will stay or not.
    Sent from my SM-N986W using Tapatalk
  6. Rock$tar
    33
    125
    21
    Jan 3, 2013
    Ram Year:
    Engine:
    Cummins 6.7L
    AlfaOBD can't change max speed. That's set in the ECM not the BCM. You need a tuner to do that properly.
  7. brutal
    brutal Junior Member
    Aug 14, 2020
    Douglas County, CO
    Ram Year:
    Engine:
    6.7L
    Doh, You're right of course as always.
    (RIF)
  8. ManualCummins
    ManualCummins Senior Member
    32
    205
    92
    May 3, 2016
    Ram Year:
    Engine:
    Cummins 6.7
    That’s not 100% true or you can change the maximum speed alpha OBD The trick is you only have one time you can change it we have successfully turned it up to 500 km several times also know one guy who accidentally put in 115 km thinking that it was miles per hour and his truck would only do like 60 Now because you could only do it one time he had to actually get a tune to straighten it out because the only other solution was to replace the entire computer
    The way that people are getting the performance pages to work I wouldn’t recommend but
    In a nutshell they’re changing it to a charger Then activating the pages then changing the back manually
    To A ram leaving the pages active the entire way and they just happen to stay there yes
    no one will make a tutorial there’s probably a 50% chance you break your truck by changing the vehicle type
    secondly every vehicle is completely different and you have to go through every single option and re-select them to the correct setting afterwards it is a very long process
    Mpgrimm2 and likes2build like this.
  9. ManualCummins
    32
    205
    92
    May 3, 2016
    Ram Year:
    Engine:
    Cummins 6.7
    that’s not entirely true we have successively changed it with Alpha mini times there is a serious issue though if you only have one chance to change it and then it stays permanently after that
  10. ManualCummins
    32
    205
    92
    May 3, 2016
    Ram Year:
    Engine:
    Cummins 6.7
    Why would you want to set it to 90 km anyway that’s only like 55 miles an hour
Share This Page
