Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
AlfaOBD
Discussion in '4th Gen DIY' started by Ghost_RAM, Jul 30, 2018.
  1. Kenepo17ram
    Kenepo17ram Senior Member
    50
    128
    33
    Oct 28, 2019
    Brooksville, FL
    Ram Year:
    Engine:
    Not at the moment.
    Sent from my SM-N986U using Tapatalk
  2. Shugarrckbx
    Shugarrckbx Senior Member
    52
    109
    44
    Mar 4, 2018
    19344
    Ram Year:
    Engine:
    That's what it shows when trailer isn't connected, mine does that as well.
    likes2build likes this.
  3. Kenepo17ram
    50
    128
    33
    Oct 28, 2019
    Brooksville, FL
    Ram Year:
    Engine:
    Thanks for the clarification
  4. Shugarrckbx
    52
    109
    44
    Mar 4, 2018
    19344
    Ram Year:
    Engine:
    Just checked mine this morning on my way to work with no trailer, says the same as yours, when I do connect to a trailer, it states connected. Glad I could help..:cheers:
    Kenepo17ram likes this.
  5. SniperDroid
    SniperDroid Senior Member Military
    65
    130
    93
    Aug 30, 2020
    Eaton Township, Ohio
    Ram Year:
    Engine:
    Check the cluster options and you will find it records a seperate Towing Milage for the Trailer. I use it to record how many miles the trailer has traveled.
  6. Shugarrckbx
    52
    109
    44
    Mar 4, 2018
    19344
    Ram Year:
    Engine:
    Oh, wow, didn't even realize that, that will be nice for when towing the travel trailer, thanks for the info!
  7. Kenepo17ram
    50
    128
    33
    Oct 28, 2019
    Brooksville, FL
    Ram Year:
    Engine:
    It worked, i hook a trailer at work and it worked.
  8. Shugarrckbx
    52
    109
    44
    Mar 4, 2018
    19344
    Ram Year:
    Engine:
    Great! I knew right away that was it, when I installed mine,I had the same confusion that you had, I hooked up to the travel trailer and all good, just the way it operates!
  9. crash68
    crash68 ACME product engineer
    6,159
    8,254
    Mar 20, 2016
    Ram Year:
    Engine:
    If you disconnect the trailer while the truck is running, you'll get a red trailer disconnected icon on the dash until you turn the vehicle off or connect the trailer back up.
    There is no problem with driving with the icon on, done it many times after dropping off a trailer.
  10. Michael
    Michael Senior Member
    1,506
    1,938
    Jan 2, 2015
    In an undisclosed bunker
    Ram Year:
    Engine:
    You can drive it like that, but I find it annoying.
Share This Page
