AlfaOBD
Jimmy07
Oh Body Computer, dodge 2018, connect and go to the car with the open hood and clear all? Oh okay instead of going to Engine I will go to ABS and go from there?
Instead of body computer or engine, choose abs.
Bigdaddy
6.7L Diesel Cummins
When I select the ABS module, these are the things is listed.
1.ABS Chrysler/Lancia/jeep/Ram
MY2006-12 Non-PowerNet
2. ABS Chrysler/Lancia/Jeep/Ram
MY2008-12 Non-PowerNet
3. ABS Bosch/Continental/Teves/Trw PowerNet
MY2013+ PowerNet
4. ABS Bosch/Continental/Teves/TRW PowerNet
MY2019+ PowerNet
5. Integrate Trailer Brake Module (ITBM)
MY2010-12 PowerNet
6. Integrated Trailer Brake Module (ITBM)
MY2013+ PowerNet
So needless to say I was at a lost here so I finally back out and thank you for your help.
Jimmy07
MY2013+ PowerNet
MY2019+ PowerNet
MY2010-12 PowerNet
MY2013+ PowerNet
Yours is number 3-
MY2013+ PowerNet
The instrument cluster will start to chime when you connect to the abs module. This is normal.
Bigdaddy
6.7L Diesel Cummins
Thank you I'm going out now and try that.
Well I did it but now I shut everything down and just waiting.
So what do or when do you do a ABS initialization, a lot of questions I know but maybe it will help other also?
Bigdaddy
6.7L Diesel Cummins
Okay I'm back again and I have it back working like it suppose to and I really want to thank Jimmy07 and Kad so much your help is deeply appreciated.
Bigdaddy
6.7L Diesel Cummins
Okay I need to work on my fuel captivity to see if I can get it to read 52 gals or 197 liters.
Jimmy07
Changing fuel capacity doesn’t work on 4th gen HD Rams. It only works on 2019+ HD Rams, and the highest value that is valid and works is 194.000
CanRebel
Toronto
I mentioned that to him earlier. put lower number.
Had issue with my 2021 rebel with tires. It wouldn't take correct number. I had to go little lower.
Bigdaddy
6.7L Diesel Cummins
Lol, you know I was thinking that after I type this that it don't work but I beginning to learn how many miles I can go when I fill up my tank and about how much it will cost to fill it up from full to 3/4 full I'm alright with that and thanks again sir.
