18CrewDually
- Nov 17, 2019
- 578
- 586
- Location
- U.S.
- 2018
- Cummins 6.7 H.O.
For whatever reason when I select MY2022 in AlfaOBD it comes up for the 13-17 option by default when I hit connect. Is that normal?
I would say that’s normal because even though your truck was built in 2022, it’s still using 2013-2017(2018) parts because it’s still a 4th-Gen truck so what I would do unless somebody corrects me is every time you use alpha OBD, make sure that whenever you connect it to your truck, tell it you have a 2018 Ram 1500 DS/DX.Hi all - need help with DRLs. I have a 22 Classic with the factory projectors. I have my settings set as outlined in post #7079 to no avail. I have even tried Canadian mode as well as setting for turn signal as location but with no luck. I have been checking to see if it is working with the truck running, in drive. I do have the security bypass module installed. For whatever reason when I select MY2022 in AlfaOBD it comes up for the 13-17 option by default when I hit connect. Is that normal?
For the rest of the tutorial, I’ll refer you to a YouTube video"]made by one of our members here, @big daddys house.[/URL]One other weird thing I noticed - these two settings do not appear in AlfaOBD:
CBC I/O right dedicated DRL lamp output present> yes
CBC I/O left dedicated DRL lamp output present > yes
Is it possible these were for an older version? Or only applicable for older model year(s)? My CBC settings for DRL reference auto-level and other such things that I do not see mentioned elsewhere. Any help is appreciated!
the CBC I/O options are for setting the Input / OUTPUT on the BCM and that feature would be for dedicated DRLs like on Chargers - A light that is ONLY for DRL and NOT wired in on USDM trucks as far as I know in Canada the HIGH LINE projector headlights use the dedicated DRL for lighting the LED turn lights but the base "quad" lighting they use the high beams dimmed downHi all - need help with DRLs. I have a 22 Classic with the factory projectors. I have my settings set as outlined in post #7079 to no avail. I have even tried Canadian mode as well as setting for turn signal as location but with no luck. I have been checking to see if it is working with the truck running, in drive. I do have the security bypass module installed. For whatever reason when I select MY2022 in AlfaOBD it comes up for the 13-17 option by default when I hit connect. Is that normal?
