AlfaOBD
miketx
So I'm still having trouble. Any users of AlfaOBD using a phone with Android 12? I now realize the last time I used AlfaOBD was with my old phone, which was a much older Android version.
Mpgrimm2
Preferred Vendor
Anderson, SC
2019 Laramie QC (5th Gen)
5.7L eTorque
My galaxy S21 is on Android 12... Seems to work okay with AlfaOBD/OBDLink MX BT adapter...
miketx
Update: I pulled out my old phone running Android 8......and it connects fine. AlfaOBD presents a big list of my BT devices to select from. On my Android 12 phone, the "Paired Devices" list in AlfaOBD is blank (even though I have dozens of paired devices). So something in my Android 12 phone is stuck and AlfaOBD can't pull the BT list. I'll talk to Alexy about it.
nekkidhillbilly
hemi
i just got alfa and have a s22 had some issues pairing up but it would finally. i had to pair it about 4 times then it finally worked.
DrTron
Jackson MS
All,
just got my Kaodtech bypass cable. I'm still without a truck to test it out, but I noticed that the male plug (where the BT-dongle goes into) only has three pins connected. Could be sufficient (power, ground and data), but I just wanted to check with you guys if that's the same on your cables. I got the one for the 2019+ 2500's.
Thanks!
pricey59
Lancaster Pa.
Ok gentleman, I have searched and all I find is resetting the orange low tire image on the dash. What I'm needing to figure out is why on my display it shows the truck tire pressure menu and the passenger side rear tire sensor highlighted in Grey in the picture is blinking
I put new ri.s and tiresbon my 2015 1500. It came with 20's so I I put on 20's with a 33 inch tire. Tire shop mounted and balanced wheels amd tires and swapped with the OEM. No error and any lights on for several weeks and then this came on. Right when I start it, this menu pops up. They are all new sensors that came woth the tires package. I lowered the pressure to close match the tire recommended pressure. They are typically all the sa.e number but on one blinks. Anying I can do with alfa or is it back to the tire store.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
I'd suspect that sensor failed. I'd also guess since it was a part of a wheel package, the sensors are cheapy China sensors so a failure can be expected.
Just my opinion and where I'd start.
Irongoats
Las Vegas
2015 Ram Sport
Trying Program Tire Size but just not getting it right what is the size in MM anyone is running that get's you close to spot on? I input 2781 according to tire size calculator website but speedo is running 2-3mph over the actual according to GPS. Do you go up in increments of 5, 10? I just know not to go to 2820 haha truck felt like manual steering and MPH showed dashed lines.
Running Toyo Open Country R/T, 35/12.5/20.
