AlfaOBD
joelmic
stl mo
2017 Ram 1500 Express Quad Cab 3.6L 4x4 20x9 Wheels
Engine light cleared, but I'm not happy about a throttle fail while going 70mph on a busy Highway... peddle commander might have to be retired... I'll give it another try but I think that's weird
gthoms334456
Canada
Hi, still unable to change odometer reading, I'm in Canada and have a 2019 Classic with a premium cluster from a 2015, tried everything, keeps saying procedure failed, using my Samsung phone
vitola1971
canada
diesel
hello, I'm wondering if anyone has the same problem I do. I bought alfaobd and obdlink mx+, I managed to set low beams to HID (have 35w HID's that I havent installed yet) I also set fog lamps to led and bought the morimoto 4banger kit for 2015 ram "plug and play", after installing the left one wont turn on and shows a fault (open circuit/short) but no bulb out notification, if I remove left and plug in a hologen it flashes like 4 times then goes out and the right led fog light now stays off showing the same code. :(. I will clear faults and plug back in the hologen bulbs to reconfirm they work. Anyone have trouble with a 2015 ram? mines limited with projector lamps.
thank you
CanRebel
Toronto
Clear engine light OR find out why it's on.
So driving down the highway and RED electric warning came on and peddle was messing up.
I pulled over and turned OFF Peddle Commander, and checked the message. Something about Throttle (something) Needs servicing.
So came home and plugged in OBD and only warning I had was some weird light bulb out of something, so I CLEARED it thinking if it's a bulb it will come back on.
No additional warnings but engine light still stays on when starting the truck.
I have no drove it around yet since clearing the warnings but I'm wondering what all happened or where I can get more info?
If engine light DOESN'T go out in time, how do I use ALPHAOBD to find why it's on??? It would give me a code right?
I had a problem like that 2-3 weeks ago.
I wasn't driving. I started my truck, and as I was about to take off. It come up and truck went limp.
Unplugged PC, cleared the codes. Worked fine. Put PC back in. Never had issue before.
I'm not sure, but I think there was mobile software update. Not sure if that was related or not.
vitola1971
canada
diesel
thank you
Turned out in the end to be a disconnected solder joint in the light itself:) I re-soldered it and its working fine now. I currently have BCM set to "LED fog lights present" no. The Morimoto 4Banger fog lights supposedly can plug right in so I'm going to run them as is and see if any faults pop up, also installed the HID 35w low beams. Wow, I can see:favorites37:
icemanch
South Carolina
5.7L
I need a bit of help. All forums point to this thread as the best place to go. If there's a better place let me know.
I have a 07 Durango/Aspen that I swapped a Eagle Hemi into. I got the donor PCM from an 09 Ram 1500. Everything works except it has an error code for the Autostick circuit being high and the transmission won't shift into low gear. I've double checked and the BCM says AutoStick not set. Is there a setting the in the PCM I need to change too?
rtodd1979
NC
newbie to AlphaOBD here. connected everything via android and obd mx+, trying to save current configuration but when i select upload faults and status logs it says that nothing exists? its a 2012 ram 2500 6.7. any help is appreciated, the truck is deleted and tuned with EFI live is that matters. all im really trying to do is get my TPMS working again. it was working then had my mechanic correct tire size when i had transmission rebuilt, now the TPMS just shows 0 on all four tires and the EVIC says maximum tire pressure and the light load tire pressure no longer works?
Dean2
Near Edmonton
First you have to populate the report.
I already posted this in this very thread and it is posted quite a few other places. This info is one page back. The instructions that come with ALPHOBD also contain this info.
Digitus78
Wyoming
I thought my last save uploaded to google but it didnt. I was playing around with the light settings ....you know becuase i could lol. Well everything still works ok except when my rear doors are open my emergency lights stay on until they are closed. Im sure its just a courtesy feature but its annoying now. Everytime those doors open blink blink blink blink and people ask if i need help. Anyone know the settings to stop that?
ThunderMug95
North Prince George, VA
Same here. Happened once when I passed a State Trooper keying his radio mic. Truck went limp. Pulled over turn engine off, i carry a code reader and cleared it, cycled the PC and was good.
