I know this is old but do you think it’ll work if I tap in a ground wire with out having to cut the existing wire?I purchased the keyfobs in the picture and changed the skins on both of my existing remotes nd that was done.. i then went to the bcm under the dash shown in pic and found pin 11 the oem mopar kit calls for removing the existing pin in it isnt used anymore and to insert new pin from latch what i did was find the wire nd cut it i then added a wire to the one coming from the bcm nd grounded it tricking the bcm to thinking there is a hood latch sensor and that its in the closed position i then using alpha set the bcm changes shown in the screen shot.. the hardest part to me was waiting for the changes to take effect mine took about 45 min but well worth the wait i now how working remite start nd love it... just to make sure i checked what would happen if i ungrounded thr wire nd when tryin to remote start it woukd give a message on cluster sayin remote start canceled hood openView attachment 414216View attachment 414217View attachment 414218View attachment 414219
On my Grande Cherokee there is a setting in the options screens on the radio screens that makes it squat every time. I would be surprised if your pickup didn't have the same.Is there a way to search just this forum on AlfaOBD?
I have read and read but can't just keep spending time trying to find out if anyone know how to make the truck auto lower when put into park, ever time.
The truck has a button to push when you park to lower it so you can get in easier, which my wife needs, but I'm trying to see if there is a setting in the controls that might be changed to make this happen every time it goes into park.
Any help would be greatly appreciated.
Thanks
Yes this will work, but you are taking the safety of the ground of the hood latch out of the circuit! This could be an issue when working under the hood and somehow the remote start button gets pushed! Have had mine start with fob in pocket! Your truck, your choice! I wouldn't want to risk loosing a finger or worse.I know this is old but do you think it’ll work if I tap in a ground wire with out having to cut the existing wire?
I guess it's a surprise, but my 2015 Laramie does not have that selection in any of the listed area. Funny that is does AERO mode when above 63 mph thus lowering, but no selection for when parking other than the manual button.On my Grande Cherokee there is a setting in the options screens on the radio screens that makes it squat every time. I would be surprised if your pickup didn't have the same.
Thanks. I need the way to check in android for my phone alsoIn the Windows version, click on "about" and it shows what you have. I checks for updates automatically.
